Low virtual memory....
KamiMazi
USA, Cali
I get this messege now randomly. It's not my RAM or settings, they are fine. Is there a way to adjust the virtual memory, or fix this problem?
Big Nuttz
Always one step ahead of jdmcnudgent
Toledo, Ohio
I received a simpiler message with XP Pro. What OS are you running? Mine problem happened during shut down. All I did was increase my page file from 384 to 512.
nikhsub1
Unoriginal Macho Moderator
Los Angeles
How much physical ram do you have? Have you messed with your pagefile settings? The default pagefile size is around 700MB.
Yodums
Senior Member
Ottawa, Canada
Yes there is, it's in the My Computer Properties.
Adjust it to the minimum and maximum are the same.
Heres what I recommend as a size for a page file:
128mb: 256mb
256 & 384: 512mb
512: 256 or none.
1gig+ : None
Defrag before setting them, make sure their saved on your fastest drive.
Yodums
