Lowering fan voltages
Amedeo602
I've read a bit about lowering fan voltages. Is there a program to do this or do I need a rheostat (according to my local radio shack, i need new fans...lol) ?
If I need a rheostat, how do I go about hooking it up and such? TIA
just place the reostat in series with the fan on the 12v (yellow) line. reostats have 3 pins, just connect the 12v line from the psu to either side of the reostat (depends on wich way you want to turn it) and then from the middle pin to the red wire of the fan. that should do it.
