- May 3, 2001
- London, England
Little River White Water vs. BeCooling SlitEdge
A quick mini-review.
I need my LRWW for a hot-running XP2100B which needs 1.95v to get to 12x200 so using it for an XP1700B that only needs 1.65v for the same speed seemed kinda wasteful.
I saw BillA's review of the SlitEdge and thought for the price, it had to be worth trying.
The block came on Thursday so it went in today. First off, to drain the water and remove the LRWW. I removed the LRWW and drained the water straight from the block into a bowl so I could re-use the water. Then I removed the out tube from the LRWW's Y-adaptor and the in tube from the centre barb.
Since I had no mounting hardware for the SlitEdge I thought I could just use the LRWW's but unfortunately the LRWW's mounting bolts are too big to go through the holes in the SlitEdge.
So that meant removing the motherboard to remove the LRWW's bolts. I have a Swiftech MC462B on the shelf (literally) so I checked whether the Swiftech bolts would fit and they did, so I attached the Swiftech mounting posts to the motherboard and replaced in the case. Fortunately, this is in my Lian-Li PC60 with the removable tray so it didn't take too long.
Then I removed the chip and re-applied some AS2 (I've been using the same tube for two years and it's still going strong!). The old tubes were then applied to the new SlitEdge and the block carefully placed over the chip. Since the SlitEdge is quite a bit fatter than the MC462, I used only the spring and one washer when trying to get the bolts through the SlitEdge and into the posts.
The first one went in OK and still pushing the block down hard against the chip, I tried to get the diagonally opposite bolt in. My tubing was in the way, but with a bit of jiggling, I got the second bolt in and partially screwed in. Then the other two went in and then I tightened them up using the standard bit by bit method. Soon all four bolts had bottomed out in the mounting posts so I knew I had a good contact.
I started re-filling using my fill tube which is a recent addition from when I tried it with just the BeCooling Pump/Res the first time. Once I'd got most of the water back in (since the new system no longer included the two outlets of the LRWW and the Y adaptor, the new system has slightly lower water capacity), I turned on the pump and watched for leaks.
The water was very frothy as it whizzed round the system. This was collecting in the fill tube as foam which I got out using rolled up kitchen towel, and then topped up with some of the left-over water.
Once the foaming settled down a little (and I didn't wait too long ) I re-connected the power and the externals and tried the power switch. It booted first time and a quick trip to the BIOS' health screen showed it wasn't going to burn up as the CPU temp settled at a couple of degrees over system. Then I re-booted and the 8RDA+ kicked in at its real settings of 12x200, 6-2-2-2, with the Vcore at 1.65v.
No problems with the boot and the health screen looked OK despite the still incredibly foamy water so I let it boot into XP.
No problems so far, so I kicked off my Distributed Folding client which loads the proc at 100% and is an incredibly tough test for a computer. MBM5 was recording the temps for me and I was very pleasantly surprised. Now the foam has gone so how did the two blocks compare?
Cooling components:
BeCooling Pump/Res with maxi-Jet 1000
Black Ice Extreme
Evercool 120mm with 120mm gutted fan as a shroud sucking air at 7v.
With the LRWW, the CPU temp was between 6C and 7C over system
With the SlitEdge the CPU temp was ... exactly the same!!!
I'm not going to claim that the SlitEdge is the equal of Cathar's wonder-block even though it is using some of his carefully calculated principles but I have to say that its results speak volumes. For £37, inc. VAT, this is one hell of a block!
Cooling components:
Black Ice Extreme
