- Feb 25, 2004
- N of splat W of Torin
I could not force a GPU(RTX 2060) into my top slot. I ended up getting it into the bottom slot and the old GTX 970 slipped into the top slot without to much trouble.
Is there a lubricant like Vaseline, that could help the contacts slide in , without me breaking the GPU. I want to put another RTX 2060 into the slot.
I can get the side in where it clips in , but the small portion near the back pf PC is what is excessively tight. I also tried going the other way, back end in first but its not happening. Conversely the 970 went right in without a fuss, the tolerance was much less.
EDIT: Maybe the back of the bracket needs to be bent in, googling this that might be hitting and I can't see it....I was in a hurry while doing it.
