- Thread Starter
- #21
What support? Would it be included with the motherboard or the drive?Did you put the support on? Should be like a rubber thingy..
It should come with the motherboard.. You thread it into the board, each hole representing the size of M.2 that you intend to useWhat support? Would it be included with the motherboard or the drive?
This is my drive with no heatsink. Not sure if this helps..It should come with the motherboard.. You thread it into the board, each hole representing the size of M.2 that you intend to use
that looks much better, when you put the heatsink on from the mobo did you leave everything on the m.2 drive plus the thermal pad that is already attached to the mobos heatsink?This is my drive with no heatsink. Not sure if this helps..
I didn't notice it before but it looked like the thermal pad from the mobos heatsink was being squished out the sides which would explain why it's putting so much pressure on the drive, I've done the same thing before but my drive had that copper sticker and even that was too thick.Yeah that looks way better dude, just run it like that I guess, or peel the thermal pad off and try it again, but really.. that bend was pretty impressive.
I removed the thermal pad completely and it was bent just the same. Oh wellI didn't notice it before but it looked like the thermal pad from the mobos heatsink was being squished out the sides which would explain why it's putting so much pressure on the drive, I've done the same thing before but my drive had that copper sticker and even that was too thick.
You would see the difference if you were actually using your PC under an extended high load. The same goes for SSD and RAM (if RAM runs at higher voltages).
Nearly every SSD designed for PS5 has a heatsink because it heats up even more when closed in the console.
The GM7000 is sold with and without a heatsink. It's an older model (nearly three years on the market) and heats up under high load. It won't overheat during typical work, but it will overheat during extended high load if you don't provide additional cooling. In short, 30-40C is idle, 55-60C is light/daily work with some breaks, and 70C+ is high load. The throttling point is typically at 75C and requires a heatsink to keep it below that temp. I don't remember if the GM7000 had it at 75C or higher. 85C is a critical temp and will keep the SSD throttling all the time, or if throttling doesn't lower the temp, then it may shut down the SSD (it will turn off and won't be visible in the OS until the restart).
Is this really normal? I mean the fact the drive is bent won't help with cooling since the contact with the thermal putty is limited. Thanks
Really, it depends on what you do with the drive. If you happen to work with and move large files around often, drives can throttle and slow performance down... especially those without a heatsink.The rest of us... probably don't need a heatsink for our M.2 drives and RAM.
No everybody is the Overclockers.com Benching Team Leader...
HELL... only YOU are the Overclockers.com Benching Team Leader!
Benching team or not (FWIW there are two leaders...), you want to get the performance you paid for all the time, regardless if most of the time you can get away with it. Hence, using a heatsink on 4.0 or greater drives is suggested.
Edit: here's what his drive does out of the box with the default heatsink...
I didn't ask to be the team's leader, but I was once asked to be one of three team leaders when we had 100+ active members, and the team needed some people to manage it (two are still around). No one pays me for anything around here, and I have spent a lot of time supporting others for many years. I don't expect anything and I never asked for anything, so at least you could respect that and hold your BS. I don't care if you know me, but you must be blind, not seeing what I have done for the last ~20 years.
LUL. If you cant see the forest through the trees here...big yikes. The point I was trying to make was generic. You're suggesting they aren't needed. People are telling you otherwise.Do you have another graph that shows overall performance when the drive's been bent into the shape of a banana for a week and a half? (I'll accept a venn diagram if you've got one...)
It should go without saying if you're bending the PCB, it's not a good idea to use it like that. Clearly their paltry 'sink needs to be removed before use with the one on the board. Come on... don't act dense/troll.
I didn't say he needed one. I'm saying that with most 4/5.0 drives, you want one in order to get 100% performance 100% of the time. If you read for comprehension, you may have seen i used the word "suggested" as well as "even if most of the time you can get away with it"..so I'm gonna err on the side of: "I've been using M.2 drives for the past ten years or so... never had a heatsink on one... got all three M.2 slots populated right now... and never had a problem. So NO: You don't need one. Just leave it off and you'll be fine without it."
I didn't say, allude, nor infer that at all. WTF???Now if you're saying you only want people to post who AGREE with you... Well hell... it's your show. Why not?
Were trying to take care of the guy.. its smack your bish *** obvious that if the pcb is bending that's 'no beuno' and we're all still trying to figure out why that's happening...its up to him if he chooses to get another that works, doesn't use one at all or continue to see why the existing one is bending the unit.. nobody is thwarting that effort.
I thought my point was painfully obvious (...that I was just filling in the blanks/adding more to 'you'll be fine' - Id want to know the whole story to make the best choice for myself...) at the time, hence the incredulous response. It seems it was neither painful nor obvious.Otherwise: WHY would you even suggest that?
