*CORRECTION* 9600 BE not 9650
I wanna upgrade the cpu on my m2n78-la from the current Phenom X4 9500 because I can only achieve 2.4Ghz stable out of it. Using Nvidia Performance Tools it can handle 219Mhz FSB stable. It's cool also because the combo of 1gb sticks at ddr2-800 defaulted to ddr2-667 in bios so it allows overclocking over-head. Apparently these boards are strong enough to run stable at ddr2-800 @ ddr2-867. Supposedly the 9600BE and 9850 WCJ has a built-in 1066 memory controller. So I could even get ddr2-1100 at 2700Mhz X 4 might do pretty solid.
So I'd like to go higher and i'm torn between the 9600 BE or 9850 WCJ 95W.
9600 BE 2.3Ghz - 1800mhz HT 11.5 multi 1.15-1.25v
9850 WCJ 95W 2.5Ghz - 2000Mhz HT 12.5 multi 1.2-1.25v
So since I know the M2N78-LA is an HP board I can overclock with nvidia system tools on a non-black edition/ black edition or in the Advanced bios CTRL+F10 allows adjustment of the multiplier.
So my question is I'm sure I could see 2.7Ghz with the WCJ 9850 with a HT rate of like 2050-2100Mhz. The 9600 BE has a multi at 11.5 x 200 = 2300. Say I set the multi to 13.5 would it run stable? Or could it pull of 14-14.5 on stock volts?
I'm just wondering if the 9600BE can overclock better with the Multi alone or would the 9850 do better increase the FSB to 219Mhz x 12.5 = 2737Mhz?
Thanks
Thanks
