ok first off i also have posted this in the laptop section becuase i really dont know where this would go!!!!!!
ok mac guys i have a friend that has a mac powerbook it is the g4 with 400mhz processor.
he is wanting to upgrade the ram to 1gig and upgrade the hard drive to about 20gig. and im the one that has to do it for him!
he has no system restore disk and he thinks it has panther on it but not sure!
and there is no product key code (like what windows have)
Now i have ever even looked at an apple before i dont know anything about them except the ram and the hard drive install will be about the same as a normal laptop.
the ram is two sticks of 512mb pc100 so-dimm 144 pin can you all help me find the cheapest possible???? so far the lowest i have found has been $29 per stick!!!
the hard drive needs to be ultra ata 66 ata-5 could you all also help me find the cheapest possible at aleast 20gig???? so far the lowest i have been able to find is about $20!!
my ?'s are what operating systems can it handle (from my research it looks like it is limited to jaguar/panther/ and tiger) is that correct?
also do macs even need a key code for the os like windows?
also could i just buy him a system restore disk?
also where is the cheapest place to find this stuff?
thank you all in advance!!!!!!!!!
also would this work to be able to completely replace his OS it says it is compatible with his laptop but im not sure is it would be a full replacement and would it come with a product code or does apple even need a key code????
