Magic Athlon Mobile 2600 ???
Dragonprince
CT
I have to ask, is this result common ? I just bought a Mobile 2600, its the I stepping. I forgot to write everything down but I believe its IQYHA 0352. Anyway I rip out the Mobile 2400 that I had running at 2.3 Ghz @ 1.75 v core and plug in the new chip thinking that the 2600 should work at lower voltage. So I start cranking it down by .05 a whack until she cries for mercy. Only thing is Im at 1.45v and the chip is still at 2.3Ghz....is this normal? I ran Aquamark3 just to make sure im not seeing things. Ran fine just like usual. With my case temp at 35c the chip is idling at 34c while I type this. Again is this normal for these chips? Because if it is ....I mean....well...Gawwdd Daammm! Sorry couldnt help that last bit... :bday:
Drec
wow...i bet it isnt prime95 stable...but either way getting it to boot at that vcore is amazing!!...that thing should be able to kick *** at 1.8v damn i bet you could get it to 3ghz with good cooling.
Cybrguy
Dragonprince said:
I have to ask, is this result common ? I just bought a Mobile 2600, its the I stepping. I forgot to write everything down but I believe its IQYHA 0352. Anyway I rip out the Mobile 2400 that I had running at 2.3 Ghz @ 1.75 v core and plug in the new chip thinking that the 2600 should work at lower voltage. So I start cranking it down by .05 a whack until she cries for mercy. Only thing is Im at 1.45v and the chip is still at 2.3Ghz....is this normal? I ran Aquamark3 just to make sure im not seeing things. Ran fine just like usual. With my case temp at 35c the chip is idling at 34c while I type this. Again is this normal for these chips? Because if it is ....I mean....well...Gawwdd Daammm! Sorry couldnt help that last bit... :bday: QUOTE]
I just received my Moblie 2600 from newegg (they rock on quick delivery) & it has the same stepping as you... can't wait to pull-out my 3000XP & do some serious ocing!!!! :burn:
Dragonprince
Dragonprince
CT
Well im at 12.5 x 200 so im done with multipliers on this board without a mod to unlock the higher multi's. 1.525v core @ 2.5Ghz...gonna have to start working the FSB,
apparently this is too much chip for this board...
Dragonprince
Dragonprince
CT
I have aThermaltake Tower 112. I doubt the SLK's give better results, but I will probably have to get a faster fan. Right now I have a slow and quiet fan, maybe 2000prm at most and Im still pulling 43c while running SETI so im pretty happy right now. My rig is very quiet so I might just stay at 2.5 Ghz for a while and enjoy the peace and quiet at 1.5v :D
Then again 2.7Ghz sounds very sweet and this chip should do it no problem...
Cybrguy
Here's an update... Out of the package this baby went 200 X 12 @ 1.6vcore w/ air cooling!!!! DAMN... this is a nice chip..
Cybrguy
I didn't have much time to fool around with it yesterday & didn't want to pump too much voltage into the chip until I knew it was ok... Just wanted to see how it looked w/ some conservative OC settings.... I'll start upping FSB, vcore & multiplier (slowly).
