- Mar 19, 2001
...I suppose my thread title is a bit misleading because I do not have unsafe temps, but rather atrociously high temps for the equipment I'm running. As I mentioned, I'm using a Lian Li PC70 full tower all-alluminum server case. I have two U1-A, 47cfm, 80mm Panaflo's in the lower front as intakes. In front of those [also blowing in towards the mobo] is a H1-A, 103cfm, 120mm Panaflo. It is fastened to the internal 3 1/2" drive cage w/ heavy duty foam mounting tape. Also, behind the CPU area are two more U1-A 80mm Panaflo's, exhausting hot air out of the case. Directly in front of those is the mother of all HSF's, the MC-462, the rev1 HS w/ the original Delta 80x38mm fan...
. In addition, up above the PSU [BTW is a 431 watt Enermax] are yet two more u1-A 80mm Panaflo's, also exhausting hot air out of the case. Now, Powerhungry [amdmb.com forums: C&C mod], and prolly some others here will notice that I've posted on this predicament of mine before. I don't remember what was said, I think PH, you told me to check airflow. Can I get a DETAILED explanation on how to do that? Also, If I remember correctly, you said you think my fans may be fighting each other. I don't see how this could be the case, given the directions I have them blowing in. If I had two 80mm's adjacent and one blowing and the other sucking, sure, I could see that. But this is just beyond me. I know the HS is flat, w/ a paper-thin layer of Artic Silver to boot. My cables are not the tricked out silver series, but homemade rounds w/ a vinyl "wrap" and electrical tape on the ends. They actually came out quite nice for a homemade job. And I think I've "re-cabled" the insides of my system a hundred times trying to maximize airflow. It sure seems to be pretty tidy in there. The proc I'm running at the moment is an 800 Bird @ 1Ghz @ 1.83v. I'm also using Daniel's [from braziliantech] 1005FXD a7v133 BIOS for the reg 52 idle cooling hack. Yet right now as I type this my board is at 27c, and the proc's at 39c!!! This is at a room ambient of 74/75f ish, around 21.5c. I'm far from being in danger of overheating or frying my system, but when I plucked out $250 for a goddamn computer case, I thought I'd get numbers like PH does in his reviews, under 35c LOAD!!! My load temps again aren't dangerously bad, they only go at most like 3c higher than where I idle. But its all about what I'm running. I've put alotta dinero in this system for fans, HS's, the CASE, etc., and its all for **** it seems. For what I've got, I'd expect to be running at like 31-32c right now, ESPECIALLY considering I'm using a cooling hacked BIOS.
The first thing you guys might mention in replying is the 120mm. But I've ran this setup w/o it, and it only makes the board run way hotter. Putting that in there had no effect on CPU temps. I've also got another one of those, and I've tried mounting it [w/ doublestick mounting tape] in front of the HSF, blowing down on it. That didn't do **** either. I'm going to get my 1.33 back on Tuesday, and if I run this hot w/ a freakin' 800, God only knows what it'll be like w/ that chip!!!
So, any and ALL ideas/help/suggestions are very welcome here. Also, lapping the HS is not an option for me. I read up quite a bit on the subject, and ended up ruining my first mc462 HS, and had to buy the rev 1 I'm now using. But please help if you all have any ideas...
