major outlook problem
whitefire05
i have a major outlook problem. I had the beta of office 2k3 and then teh beta ran out, so i uninstalled it and reinstalled office 2k2(XP) which i own(legaly) outlook wont start now ive tried reinstalling and everything. here are the messages i recieve.
Unable to open your default e-mail folders. Could not open teh item. Try again.
so i click [OK]
then i get would you like to open file system folder instead [YES] [NO] if i click no program closes if i click yes i basicly get my computer nothing else. no options or services tags i cnat find anything.
whatever you can help me with would be great THANKS GUYS
turd
Depends if you want your old mail or not.? If not the first thing I would do is run a search for *.pst and delete all I find. Then restart Outlook and see what happens. Caution!!! deleting the .pst files will remove all of your previously stored mail folders. But looks like MS is not gonna let u have them anyways. The next step after the delete, if outlook wont open would be to uninstall and re-install Outlook 2K and hope that it will now create readable .pst files for u.
These are just the first thing i would try,( if i did not want my stored mail)
redduc900
Inactive Moderator
Portland, OR
Try creating a new profile...Start | Control Panel | Mail | "Show Profiles" button | "Add" button | Name the profile, and then click OK | Click "Add a new e-mail account", and then click Next | Click a type of account, and then click Next | In the E-mail Accounts dialog box, enter the necessary information, and then click Next | Click Finish. If the "Always use this profile" option is selected, select the profile that you just created, and then click OK. :)
