- Oct 14, 2007
So...I've been looking into this thing after going ahead and starting Rosetta for the harvest and have a few questions.
In the preferences, you set the amount of CPU to use, 100% of course. You also set number of processors, so I set it to 8, for my i7 w/ HT. Then I got to the setting that tells it when to start crunching after the computer is idle...and I sighed.
You see, Folding@Home, which I've done for the past few years, runs 100% all the time 24/7. It is just at low priority, so when you want to do some computing, it gives up the CPU cycles that are needed for said task. This uses every single CPU cycle that you are not actively using.
BIONIC appears to display the annoying behavior of just plain stopping when you're at the computer. This is very inefficient; it's giving up many, many clock cycles (on many, many computers) while the computer is in use....as verified by its piddly use of the CPU while I was browsing around last night.
So, I guess my question is - can we change the client to act more like Folding@Home? I want my computer actively working to further the science...all the time. There is very little reason to give up the whole CPU just to browse a forum.
Also, should I choose to go that route, what does one need to do to use your GPU? If it does that by default, what do you need to do to turn it off? (It's an older GPU, second hand so no warranty and I can't afford to lose it.)
My apologies if these are answers already given. I'm at work and after cursory searching, I need to get some work done and it was faster to type this. Feel free to answer with links only and not re-answer things already asked. Thanks!
