- Sep 26, 2007
So I have this old dual PII machine that I've been working on. In the process, I swapped out the old Klamath PII 266's for some Katmai 500mhz PIIIs. The machine is limited to 66mhz bus (440LX chipset), so the new chips will only run at 333mhz, and the BIOS mis-recognizes them as dual "Pentium Pro 333mhz," but they work otherwise. I've booted a Linux liveCD and have run a prime test on 'em, and everything checked out stable.
Windows 2000, however, does not seem to be so happy with them. Setup freezes if I try to install with 'em in there, and if I install Windows with the original CPUs and swap them out afterwards, Windows will freeze at the startup screen. I've heard about this problem before, something to do with HAL not liking the mismatch between the CPUID and the BIOS, IIRC. What I want to know, though.... is there anything I can do to get around that? I've tried XP as well, but it does the same thing.
And I already have the latest BIOS on the machine.
