- Nov 20, 2003
- Sydney Australia
Well, right after i installed my Thermalright SP-94 heatsink onto my CPU, replacing my Globalwin CAK4-88T, the temp probe for my CPU from the Hardcano, which came stock with my Thermaltake Xaser III V2000A case (damn that's a mouthful... err... fingerfull...) stopped working for some reason.
I have the probe right under the CPU inside the socket with the wires running through the pins. I also added one Delta 80mm 5krpm fan to fan 3 as well as 2 Fonsa 4.5krpm on fan 3, one identical Delta on Fan 2 and a Coolermaster Blue Cold Cathode on Fan 1. I think the fans are on a completely separate circuit, but it's worth saying...
The fan controls still work, but it displayed 3 dashes (like this one --> - ) for my CPU temps, but the max temp still works, then yesterday, the max temps turned to 3 dashes as well. Then today, both came back online again, but only for short bursts and the CPU temps come back incorrect. They were reporting temps of up to 68 degrees C and im pretty sure that's inaccurate cuz Asus Probe is showing temps of around 27 degrees and that usually means my CPU is at 32 degrees C, plus, it was perfectly rock stable. But these innacurate temps only last roughly 2-3 seconds, then the hardcano goes back to 2 lines of "---".
I checked the connection to my hardcano and the wire dosnt seem to be damaged. I gently yanked both of the green wires to the underside of the CPU, but neither of them seem to be broken.
After writing all of that, i looked again and the display has kind of changed. Now, the max temps show HHH and not ---, the CPU temp is still the same ---.
Or is it just low batteries?
Thanks for any input
