- Nov 13, 2001
- Ioannina, Greece
I just installed an Thermalright AX-7 with a Delta 80x38 SHE (68 cfm) and IT IS LOUD. I MEAN REALLY LOUD! I mean I was expecting it to be loud, but certainly not THIS LOUD! Suddenly a vacuum cleaner seems way underpowered
As far as temps go though, I saw a huge improvement. I had a GlobalWin WBK fitted with a 80x25 ~40 cfm Sunnon and with Sandra burn-in (cpu arithmetic and mm tests only) running for 30 mins, I had:
- Room T = 20 C
- CPU T = 57 C
- M/B T = 22 C
Now with the AX-7 and the Delta 80x38 SHE:
- Room T = 20 C
- CPU T = 38 C
- M/B T = 17 C (lousy way to measure m/b temp, the reading comes from the northgate which is just next to the cpu socket and I guess the increased airflow messes with it)
Oh well, I guess it's rheostat time...
PS for anyone with an A7V266: The AX-7 was blocked by a capacitor which is next to the socket (as I figured in another post), so I had to trim it a bit. A 2-3 mm corner cut is sufficient for it to clear the capacitor. I will hopefully post some pic of it, but then again, I always say that
Work and deadlines come first, unfortunatelly...
Asus A7V266
Athlon TBird [email protected], v-core=1.79
- Room T = 20 C
- CPU T = 57 C
- M/B T = 22 C
- Room T = 20 C
- CPU T = 38 C
Asus A7V266
