Mandrake Linux Updating Problem
Beelzebub
Irvine, California
ACK!! I ran the Mandrake Package Updater on my system to update to the latest kernel version and now it won't boot!! HELP!!
I am dual booting using Grub, and when I tried to load Linux after running the updater, it says that I cannot boot the system, file not found. What did I do?!?! Grub comes up and I can boot to Windows XP no problem, but Linux no longer boots.
Is there anything I can to do fix this other than reinstalling Linux? The Mandrake Package Updater program installed a lot of updates, and finished with no errors.
Beelzebub
Beelzebub
Irvine, California
Here is the exact text that is returned when trying to start now...
kernel (hd1,0)/boot/linuz root=/dev/hdf1 hdc=ide-scsi devfs=mount quiet vga=794
Error 15 : File not found
XWRed1
Senior Member
I've heard other people complain of this problem in Mandrake. Apparently, its a bad idea to upgrade the kernel using the Mandrake updater.
David
Forums Super Moderator
You need to find a kernel somewhere. Even a basic 2.4.x kernel would be fine for a short while until you compile a new one.
The easiest thing to do is reinstall.
Beelzebub
Beelzebub
Irvine, California
I reinstalled the OS but didn't format the /home partition. At least it saved me the trouble of reconfiguring everything and crunching SETI all over again. I was at 93% dagnabbit. I would hate to waste those hours. I guess I learned not to update the kernel through the Mandrake Package Updater(Killer).
Thanks guys.
David
Thanks guys.
The easiest and safer way to update your kernel is to download the source from www.kernel.org and manually configure it.
To be honest, if it doesn't need updating, don't update it. Any 2.4.x kernel should cope fine.
