M
marty
Guest
Has anyone tried to manually change there BIOS settings? The article that explains it is here:
sysopt.earthweb.com
The reason that I am interested in this is that there has to be a way to manually write just about anything to the BIOS. For example you could change the voltage past what the soft menu allows. Likely you could change the voltage even if it isn't in the softmenu.
This is essentially what the programs that manipulate the BIOS settings do. SoftFSB and CPUCool are writing to the BIOS. If we knew the commands and settings we could do this from a DOS command line.
I think it would be interesting to do voltage changes this way rather than with the wire trick.
Changing BIOS Setup Settings that do not Appear to Exist
In many cases, BIOS setups' will not allow very many system settings to be altered. Some only allow floppy/hard drives to be configured, along with other minor settings. This is a major drawback due to
