FEATURED Marathon Season V November: Realbench
Johan45
I keep seeing realbench pop up at the Bot in their competitions, which has me thinking it might get activated for points. I just figured it would be good to spend a bit of time getting to know this bench and maybe find out what makes it tick.
What: RealBench HWBot version
Who: any forum member
CPU: any CPU
Cooling: any cooling type
When: Ends: November 30, 12 Midnight EST
Background: Use supplied background
Download :Realbench HWBot Version
Benchmark rules from HWBot.org http://hwbot.org/news/14268_application_183_rules/
Full Competition Rules: Here
I would also like this format used at the top of your post please UserName/CPU/Cooling/ Score
BACKGROUND
AMD
Johan45/FX-8370/H20/113296
t1nm4n / FX-8320 / Water / 101475
Kenrou / FX-4300 / Air / 68156
INTEL
MetalRacer / i7-6950X / LN2 / 243295
MetalRacer / i7-6950X / water / 218487
jiccman1965/6950X/LN2/218450
MetalRacer / i7-5960X / Water / 207003
Earthdog / i7-6950X / Water / 205921
MetalRacer / i7-5960X / Water / 197340
Earthdog / i7-6950X / Water / 189962
Mandrake4565/6700k/water/160797
Mandrake4565/6700k/water/158986
dejo/ 6700k/ Air/ 158970
Earthdog / i7-6700K / Water / 158582
SwartHack/i7-6700k/water/157341
Kenrou / i7-6700k / Air / 156432
Earthdog / i7-6700K / Water / 156288
Kenrou / i7-6700k / Air / 156228
dejo/ 6700k/ hyper212/ 151838
Earthdog / i7-6700K / Water / 151177
Lochekey/6700k/water/132086
Johan45
Johan45
According to HWBot all OS are allowed for this bench. For our internal comps I'm not too sticky on OS since some here only bench for the marathon and not seriously
EarthDog
Gulper Nozzle Co-Owner
Buckeyes!
Does gpu have anything to do with this bench or is it all cpu? I use it as a cpu stress test like silicon lottery, lol!
Johan45
Johan45
Not sure but I think it will effect the score, HWBot requires GPUz
EarthDog
Buckeyes!
Thanks gents...!
Ok, eventually I will run it all the way through... since the wind has twice now moved my mouse cord and subsequently my mouse and stopped the test mid way through... :rofl:
Johan45
Johan45
Eat less chilli...problem solved :rofl:
EarthDog
Buckeyes!
Heh... 4.2 GHz 6950x (daily clocks), but realized my memory was really low and didn't touch the GPU (though on the 6700K the score barely moved when I went from stock to overclocked on the 1070).
Feels like we should have the GPU if its using it, no?
Earthdog / i7-6950X / Water / 189962 (GTX 980Ti Xtreme Gaming @ Stock)
Kenrou
Uses the GPU for the h264 encoding, mine activated the full boost somewhere along the bench. Core count FTW :rock:
Johan45
Johan45
I guess we'll have to see how much of a difference it makes.
EarthDog
Buckeyes!
OpenCL uses the GPU. It kicks up in the encoding to put the images on the screen, but promptly goes back to idle clocks. It then fires up to full boost in the Open CL test (Luxmark) and drops to idle after.
Earthdog / i7-6700K / Water / 151177 (GTX 1070 @ 2088 Actual Boost/2107 Mem)
Johan45
Johan45
HWBot has it listed as a CPU benchmark BUT the top scores are using 3x R9 290x likely since AMD has the advantage in OpenCL
EarthDog
Buckeyes!
Why is it occasionally the encoding doesn't start right away borking your score? Does that happen to anyone else?
Just to make Kenrou run it again to beat me. :p
Earthdog / i7-6700K / Water / 156288 (GTX 1070 @ 2088 Actual Boost/2107 Mem)
Johan45
Johan45
Wait till you see my 5.4 ha ha
EarthDog
Buckeyes!
My 1070 can't seem to come close to his 980Ti... I wonder if swapping to that and overclocking it would help on the 6700K for an even higher score. Truth be told, I am not sure how much my CPU has left in it. She gets wonky much past 4.8GHz. I also don't think my memory can reach that high either. Ive got an uphill battle me thinks. :)
:attn::beer:
