Dialing in the Ram? When ya putting it on the loop/good stuff?
this just dont want to bench for me at all
For some reason the submitter is wraaped in a winrar skin. Why is that? Should be a java skin
After changing the platform clock setting did you reboot? It is needed to take effect. Also make sure you change the setting as administrator otherwise it wont work.
go to the run box at the bottom left type in CMD> right click on it and run as admin. When command window pops up type bcdedt/set useplatformclock true then hit enter and reboot. If it's not working you may have HPET disabled in BIOS. Some BIOS do give you that option
