Nice Run AleAleslammer / Athlon II X4 640 (Zosma) / Chilled (5C)./ 16m 4.031s
CPU has been unlocked to use the Level 3 cache / no wasa
The good ole days when you could go cut the lawn while 32M was running![]()
I am still trying to figure this out, memory is so tricky on this platform. Tighter timings is not always better, XMP was only about 2 seconds slower. The biggest thing I have learned so far is to keep FCLK, UCLK, and Memory all 1:1 (3600 memory for me). Bumping the memory up to 3800 puts UCLK in 2:1 mode and it kills efficiency. As you can see here, benchmate makes a pretty big difference in the total score.
PUSH IT! GO GOI might be able to squeeze something out last minute but.......
Not sure how to read your statement:I have seen others run 1900 fabric, but my two CPU's cant do it. In geekbench 4600 14-13-13 with tight sub timings beats 3600 12-11, but only by a small margin. The fabric always stays maxed at 1800, but the UCLK (seen in CPUz Memory tab) hurts performance in 32m to run 2:1. I tested 5000 18-24-18 micron E-Die and it's terrible for efficiency because of the loose sub timings required. Out of all the sub timings there are 3 that do the magic, everything else can be auto...![]()
Can't get to 3600 CL14 and can't get over 3600 period :/
