I don't know how you are getting good scores with Micron, it's completely worthless for benching here. Samsung totally destroys Micron for benching purposes. New AGESA doesn't help much, if anything for Samsung and maybe a little help for Micron. You don't have 1.0.0.4?? It's finally out in the wild now on most boards. I have seen a similar wall with dual channel micron at 4800 on Taichi. With the Aqua, 5g is very easy but 5100 is not possible in dual channel.
What AIDA64 image did you see? Here is an AIDA shot I did that is looking quite fast. Micron is running about 50k-52k for the top 3 It's only for maximum frequency validation IMO...or looking cool maybe.
having a hard time trying to force 5+ghz in windows xp. I disabled speed test and c-states and turbo mode. i also made sure that i set manual voltage and set the board to "performance mode".
This is in the Z370-E GaMiNg
How do you guys get your processors to stay running at 5+ghz in windows xp?
1. AGESA 1.0.0.4 is not officially out and it's not available for any of my boards. I wasn't asking my contacts for beta BIOS and I had no time to browse the web for any leaks.
2. I didn't say that Micron is better but that Samsung, depends on the motherboard and some other things, is acting weird at higher clock. It's not overclocking as high as on Intel and often tightening the timings is not helping much or not at all. In pure bandwidth tests like AIDA64 or benchmarks like Spi32M or Geekbench, Samsung is always better but because of how this platform works, the difference between memory settings is not always significant in most other benchmarks.
I should be more clear that my comparison was made on 6-8 core chips and they're hitting a wall in bandwidth and then tweaking the RAM is not helping so much. I wasn't testing anything higher than 3700X till yesterday. The difference in bandwidth like read and copy in AIDA64 is over 10GB/s between 6/8 and 12+ cores. It highly affects how some benchmarks are acting. I was comparing my results some time ago with other users who have the 3900X like Shawn. We had a bit different experience with results and memory settings.
3. This is from G.Skill press release:
It beats your score in read and is not far in write and copy while memory is at 4000 CL15 and CR2 with as I assume relaxed subs as always in XMP. Additionally it's 32GB kit, not 16GB.
I would set the CPU to 2 or 4 cores and disable HT. Also, depends on the CPU and your cooling, you have to bump the voltage as others already suggested. Turbo has to be enabled or the motherboard will lock the CPU at non-turbo ratios.
Nice, thanks. I couldn't find it anywhere. At least one out of 3 of my mobos got it but I mostly test memory on the Impact right now so it's fine. I also got the 3900X yesterday and it works with memory at 5000 and fclk 1900MHz. I will update my result in this thread once I check some settings.
