Hi Folks
Been wondering about something for a while and haven't had the luck I'm looking for yet so figured I'd ask.
How do I connect (vga hotwire) matrix edition cards to either a ROG motherboard (for example, atm am working with a rive-be) and/or the OC Panel?
Have quite a few matrix cards from both green and red teams. Some have a small connector socket (for example, the 580 matrix cards), others have just holes (figure those need soldering) and others have connector sockets plus holes and lousy documentation (like the 780Ti's).
The motherboards (mve, rive-be) and oc panel have multipin connectors.
Anyone know about this stuff? For the cards with a connector socket...are there 'standard' cables with the vga plug on one end and the mltipin connector on the other end? I've been searching but can't find anything out there (maybe my search terms are lousy?). Haven't even been able to find the connector plug for the cards at all. What the heck? For the ones without a socket...are there 'standard' cables with the multipin plug on one end (for connecting to the mobo or oc panel) and just bare wires on the other end to be soldered to the cards?
Any ideas, sources, etc?? Would love to get these all connected and working.
tia (again)!
tia (again)!
