yo
nowaday, most ATX case came with the holes needed for mATX mobo on the mobo tray, so don't worry....but there are some older ATX case that won't support mATX. you can take a look on the mobo tray, there should be some markings to indicate which holes are for ATX, and which are for mATX.
