Max 4890 OC
mxthunder
Northeast Ohio
Depends, some as little as 900, some can reach 950-960. Using msi afterburner, you can boost the voltage to 1.35 and reach the high 900's usually.
Neuromancer
Tau'ri
Editing the ini file in afterburner lets you adjust voltage a lot higher than 1.35 :) I fixed my stock cooler and well over 1000MHz is doable :)
Neuromancer
Tau'ri
I have run it up to 1100 with 1.4325 90% fan speed (i have never set 100% I dont know why LOL) and run Furmark in 640x480 stability test mode. But it is not really stable cause I cant bench it :(
johnm
Max 4890 OC
The early ones dont oc to good power regular parts get to hot.
Both of my cards run at 1.35 1.2v.
My early MSI @971 1071 needed a voltage increse to run stable.
MY 2nd 4890 is a HIS turo+ but is a decap version.
Decaps and circuit changes = a higher oc and a cooler running card.
The HIS gpu is 12c cooler on the Gpu.
The HIS will run at 1040 and 1100.
Do to CF both cards are set @971 1071.
Raising the volts gets the power regulating circuits temps to high.
