Max Memory for a laptop
Superman
Michigan
Does anyone know what the max amount of memory you can put in a IBM Thinkpad 770 with a 233mhz cpu and was made in 1997. And also what type of memory it takes. I've looked all over the place and I cant find anything. If you can help thanks.
mbentley
Gloriously Lead, Overclockix Chief Architect
Indianapolis, IN
try to enter your information about your thinkpad here. i am not sure what type of thinkpad you have (as there are so many different models) but i can usually find anything i need to know about a thinkpad on there. just look around a little and you should find some tech specs.
Silversinksam
Moderator/ Silver Paste Taster©
Sunshine State, USA
Another way is to download SisoftSandra and under the 'Mainboard' tab it will tell you the max memory you can install ;) (Plus SiSandra has a ton of usefull shtuff)
