Max multiplier setting for Asus k7m
Anticus
Hey guys, I'm running a classic 500 on a k7m, clocked to 650, using afterburner gfd. I'm about to upgrade to a slot-a thunderbird. I'm going to use my same gfd on the T-bird. In sandra it says that the max processor speed supported is 800+, whatever that means. If the max speed is 800 I'll buy a 650 or 700 and bump it to 800, but if it'll go higher, i'll get the 900 and take that as far as I can. Anyone know how high I can go? Thanks in advance, you guys are a lot of help.
A bios update might help - when I run the 1003 series bios on my A7V it tells me my max speed is 800, but it let me run my duron at 1000. When I upgraded to 1004d, or any of the 1005 series, it says my max speed is 1200 - and I can still run my duron at 1gig :)
