Max temp for Northwood
Konowl
17 degree room temp, what is the max temp (safewise) for a P4 1.6A cpu? I've got a PB266-c and am assuming the temp reported by MBM is in fact correct. It's reporting 38 degrees at 2239 MHZ with 1.7 voltage.
Cooler666
Disabled
if your load temperatures get towards the high 50's then you should start worrying, buy your temps are fine
