- Nov 16, 2002
- Neenah, WI
Figured I'd start a thread on this. This was prompted by some posts I made in this thread (https://www.overclockers.com/forums/threads/settling-into-the-6-spot.805575/).
The purpose of this thread is to quantify differences in performance of cards on different platforms, and to post the results of my testing, as well as observations. It would be awesome to get some more data to compare / other suggestions / etc. My goal is to gather enough info in here to show how much PPD can be garnered via upgrades other than a different video card. I believe our team has a lot of PPD available with just optimizing things like matching video cards with the right systems in the case of someone with a farm, free things for dedicated folding rigs as well as things like dual booting systems like a gaming PC that you want windows on but doesn't get used when folding, and cheap upgrades like finding cheap CPU/Mobo/Ram upgrades that can garner similar amounts of points vs upgrading to a faster GPU.
Some info I posted in this post (https://www.overclockers.com/forums/threads/settling-into-the-6-spot.805575/post-8213466):
"I'm snagging some data from the 4070ti while it's in the 2500k system. Preliminary results show a significant decrease in PPD vs pcie 3/4 systems with faster cpus. Not sure how close these differences translate compared to older cards but I've seen some people running 30xx and 40xx cards in older systems. There could be a significant amount of efficiency and PPD on the table with fairly cheap upgrades.
I'll have to quantify it based on the data I've collected, but for example, my overclocked 4070Ti in my 2700x @4GHZ (pcie 3.0 x16) is pretty much on par ppd-wise with a stock 4070 super in the 5900x (pcie 4.0 x16) in Ubuntu. There's normally about a 20% difference between a stock Ti vs Super. The stock Ti in the 5900x, even with the super in it (so pcie 4.0 x8) in ubuntu, out performs the overclocked Ti in the 2700x system by a couple million PPD.
A Pcie 4.0 board, CPU and ram can usually be had for like $350 or less on Facebook marketplace. Heck, the Dell 5820s Kyle has can be snagged for as little as $100 (add a ~$60 CPU upgrade) and you have room for 2 cards at full pcie 3.0 x16. Removing or minimizing bottlenecks on newer cards can give big gains!"
Some more info regarding comparisons of CPU power and platform:
Mainly wanted to drop some more info regarding questioning performance of 4070 Super vs 4070 Ti in this post (https://www.overclockers.com/forums/threads/settling-into-the-6-spot.805575/post-8213603) by @EarthDog : .
On a high PPD WU, here's a comparison between the 4070Ti and 4070 Super. Both are running PCIe 4.0 x8 in the same system. This is with the Super in the top slot and Ti in bottom, from what we've observed, Top slot almost always performs better than bottom slot even with identical cards (even when running in a 4u so temp differences aren't as drastic as in a tower).
This is about a 21% performance increase over the Super.
Also regarding 4070Ti in 5900x vs 2700x system, The 5900x Ti is on PCIe 4.0 x8 vs the Ti being single card in the 2700x system on PCIe 3.0 x16 so differences are mainly Ubuntu and CPU (Ram slightly, but both are DDR4, 2700x is 3000, and 5900x is 3600). I will have to dig for some more direct comparison results to quantify Ubuntu gains vs CPU.
I'll try to post more data in here as I gather it / post it.
Settling into the #6 spot.
We still have a slight downhill trend in our production but as of late, we have picked up production considerably. With summer fighting to stay active here, Fall temps will soon be here. I know that my production will increase as will that of several other teammates in addition to members of...
