- Apr 1, 2008
- Mechanicsburg PA
Finally stable @ 3.6 GHz 10 hrs. prime small FFT's
Settings as follows:
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting :9
FSB Frequency :400
FSB Strap to North Bridge :400 MHz
PCI-E Frequency:100
DRAM Frequency: DDR2-1066 MHz
DRAM Command Rate :2T
DRAM Timing Control: Manual
CAS# Latency :5
RAS# to CAS# Delay :5
RAS# Precharge :5
RAS# ActivateTime :12
RAS# to RAS# Delay :4
Row Refresh Cycle Time :55
Write Recovery Time :5
Read to Precharge Time :Auto
Read to Write Delay (S/D) :9
Write to Read Delay (S) :5
Write to Read Delay (D) :5
Read to Read Delay (S) :4
Read to Read Delay (D) :6
Write to Write Delay (S) :4
Write to Write Delay (D) :6
Dram Static Read Control
isabled
Ai Clock Twister :Auto
Transaction Booster
isabled
Relax Level:1
CPU Voltage :1.36875
CPU PLL Voltage :1.52
North Bridge Voltage :1.39
DRAM Voltage :1.90
FSB Termination Voltage :1.34
South Bridge Voltage :1.05
Loadline Calibration :Auto
CPU GTL Reference :.063x
North Bridge GTL Reference :.067x
DDR2 Channel A REF Voltage
DR2-Ref
DDR2 Channel B REF Voltage
DR2-Ref
DDR2 Controller REF Voltage :Auto
SB 1.5V Voltage : Auto
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :Enabled
CPU Spread Spectrum : Auto
PCIE Spread Spectrum : Auto
Advanced CPU Configuration
- Ratio CMOS Setting :9.0
C1E Suppport : Disabled
CPU TM Function : Enabled
Vanderpool Technology : Enabled
Execute Disable Bit : Enabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
Thanks to the people at OCforums for the help
Extreme Tweaker
FSB Frequency :400
PCI-E Frequency:100
CAS# Latency :5
RAS# Precharge :5
Transaction Booster
Relax Level:1
DRAM Voltage :1.90
USB Configuration
