- Mar 15, 2016
- Brisbane, Australia
I couldn’t find much on the ‘CPU Level Up’, so thought I would share my experiences here.
I recently updated the BOIS from original to see if it would help the overclocking, and found it to be marginal on my current settings:
100 x 46, Min 46 Max 46, 1.285 v, Spread and Multi Core Enhancement off. Everything else on default.
This setting is good for Cinebench R15 and my DAW (Studio One), but will crash with Prime95 which requires many more volts or a reduced multiplier.
Coincidentally, the CPU Level Up setting had an option for 4.6, so I tried that on its own. It would not boot without increased voltage and resulted with a peak of around 100 x 39 at 1.285v while testing; useless.
So I returned to the settings above, as well as Level Up at 4.6 with these results:
1. The voltages became variable for each core, instead of permanently at 1.295 according to Asus AI, now the range is from 0.00 to 1.34
2. My Cinebench went up from 905 to 928
3. The system is less stable, but acceptable
4. Temperatures cooler
I’m still a bit formulaic and not instinctive with overclocking, but after hours of messing around have decided I’ve reached the point of diminishing returns for more speed under 1.3v.
Comments appreciated.
