mb or video card?
wildone
Senior Member
TN
I have this in general hardware but it may be better placed here.I am building a friend a pc,it has a FIC AZ11E mainboard and is as unstable as they come!I have tried 3 different hd's withe the same BSOD and registry errors,I have already RMA'ed the processor thinking that was the culprit and so did tech support,I tried different memory to no evail but since I lost my pc to a bad flash I was gonna go ahead and use my proccessor to configure the system so it would be done when I got the chip back but it is doin the same thing and I know my proc. is good. I can start it up and it will run fine for a few(very few) min,what can it be,I have also tried different DIMM slots for the memory and it doesnt work either,I know you are suppose to start with DIMM 1 and go from there,but answer this I got it in DIMM 3 and in bios it says its in DIMM 2? Please any help would be appreciated and here are the specs
FIC AZ11E
850 thunderbird
128 pc-133
30 GB WD ATA 100 7200 rpm
anhilator 2 mx
Thanks, wildone
u running windows 98se? which 4in1's did you install? Most of my Blue screens were caused by bad sticks of ram. did you close the L1's? if so clean them off and try without L1's closed. If all else fails I would flash to the newest bios and then return it if it doesn't solve your problems.
Ihave tried win98 and win me and its the same thing with both,I installed the 4in1's that came with the mb,and I did try different stcks of ram and still have the same problem
