Thank goodness for mb5. I had just got done cleaning the dust out of my water cooled rig. I went and reconnected everything and fired her up. After about a minute i started to smell something, the next thing i knew my system started to go into its shutdown mode. After it was shutdowned i noticed that the power supply strip that my water pump plugs into was not turned on nor was the pump plugged in . So i then turned the pump on to cool the cpu down then i took the water block off and reapplied AS3 to it.
Thank goodness everything is fine. It is a good thing that i took the time to set up MB5 properly, i have it set to shutdown at 36c.
