- Jul 27, 2001
- Southern NY
I have noticed between these 2 ways of temp monitoring, i get different readings. But not by a couple degrees.
For example, in mbm i would get
cpu:51c (which agrees with via hm)
system: 40c
and in sisoft sandra's mb info, it reads:
cpu: 41c
board: 25c
power/aux: 52c
(these temps are with the stock hsf from amd boxed cpu, and the cpu is set @ 1200)
it seems that the power/aux reading in sandra is actually the cpu beacuse a 10c diff. is a bit much, u think?
I know if i get a thermistor, that will be the best way, but until then?
which way should i go?
system: 40c
cpu: 41c
board: 25c
power/aux: 52c
