- Feb 2, 2001
- Chicago, IL
Last night I finally got the chance to install the digital thermometer from crazypc and I've double checked the positioning on it and under max load it's about 10-12oC lower than MBM5 for cpu temps. I downloaded radiate 2 and I'm wondering if there's something weird going on. I input all my info:
cpu speed:1480
Core voltage:2.04
AMbient temp:27oC
CPU:38oC
It tells me my C/W rating is 0.11. Is that TOO good for my becooling watercooling rig and tbird combination? OR does that sound about right? I'm worried my thermometer is off like AMDGuy's was however the ambient temp outside the case Imeasured with it was identical to the ambient inside the case with MBM5 and I've got great airflow so should be running ambient temps for case temp.
Thanks.
**Modification***
I just read the becooling review that was done in february and the cooling C/W was .13 so I think my measurements are okay. ANy ideas?
cpu speed:1480
Core voltage:2.04
AMbient temp:27oC
CPU:38oC
Thanks.
**Modification***
