Hugo 59 (Feb 28, 2001 01:37 a.m.):
I've been reading all the posts for the last couple of weeks and I finally decided to go with the iwill kk266 mobo and an 850 Tbird. I thought I'd decided on the swifteck, but after reading all the posts I just cant decide if its worth the extra twenty-five bucks. Should I just go with the FOP 38? This is going to be my first attempt at overclocking and all your help is appreciated.
## I would say if you are going to go with the Swiftech it will be a bit quieter than the FOP 38 will be. The 370 Swiftech got top rankings for alot of cooler roundup's which should tell you something. I am currently running Dual FOP 32-1's on my dual Mobo and they are nice and quiet. It's all I believe a matter of preference...
I will also say this I am firm believer that your overclocking attempt will only be as good as the Heatsink you put on it to protect it... Keep that in mind when making you decision. ##
