HI ,I just receive my swiftech mcx4000 to put on my bd7II but the thing is that the heatsink is so large that it touches the resistors at the back of the board is this dangerous ?
thx in advance , I can not push the resistor ...
Yes it is.
You might be able to coat the resistors with something to prevent shorting...but I don't remember what the name is....maybe a peice of tape could suffice.
Either file or cut away the heatsink for clearence, or get a smaller unit. Insulation of the resistors will not prevent them from holding the heatsink away from the core.
thx I put it anyway but i have some issues , it starts without problem and i've been able to play a 3dmark2001 for one hour but then when i rebooted it refused to power on 3-4 times ... and then again started
I gonna try to put some plastic or anything to prevent the short ...
Good call on the plastic, my mcx-4000 barely fits on my IT7, it comes really close to a line of capacitors on one side but doesnt quite touch. It looks like there is a lot of space but that is one monster heatsink . At least we can both get it on there though, barely fitting is definetly better than not at all...
