Mdk cdrom help
Stupotaso
Orange County CA.
I can't get my plextor 16x12x24 burner to work also toshiba dvd player will not work.
both say
file:/mnt/cdrom You do not have access rights to this location.
How do i change it think it has something to do with root dir.
Jeff Bolton
Middle Peninsula Virginia
you need to log in as the root user and change the permissions on the /mnt/*** folder so that you can use it as a regular user...i think that should solve the problem but i don't know since that's never happened to me.
jeff
gaccm
that might not solve it. The standrad answer to this problem is to look at /dev/hdc (or whatever your cdrom and dvd player are) you can find out in /etc/mtab. and make sure those are world read/writeable. and in your /etc/mtab, make sure regular users can access them (read the man page, it involes putting the word "user" somewhere)
XWRed1
Senior Member
What exactly are you trying to do here? cd into /mnt/cdrom and do an ls? copy a file there? mount a drive there?
Stupotaso
Stupotaso
Orange County CA.
mdk cdrom
I found them root protected in file manager root dir file :/mnt The two cd rom drives are protected , floppy and zip drive not. Still can't change to user at a lost to remove the lock.
floppy and zip are mountable.
Samurai_Punch
CP Howze, S. Korea
I remember having a similar problem like this, where i couldn't access my CD drives (both SCSI), i think it was partially due to a wrong module being loaded, as well as the drives being mismounted... Checking the kernel may help w/ DVD issues, a friend of mine's wouldn't work until he had recompiled to include some DVD options. and setting the drives to supermount as the file system may work too.
Stupotaso
Stupotaso
Orange County CA.
re cdrom
I gave up and reformated started over now my burner works dvd still not working but think its a minor problem.
Thanks all for the help
