Media box or TV
Cown
Denmark
Hi guys.
I was wondering if anyone could help me with a little problem.
Is it possible to find a Media box which support slideshow viewing of powerpoint files or word documents on a TV through an USB stick?
The ones if found only support JPG, PNG, GIF etc.
Also if it's possible, the best thing would be if it was built in a TV, but again, I can only find TV's supporting JPG files through USB.
Thanks in advance :)
I think after you done making your pp you will convert it to a video file. Before i heard that problem not so sure about it. But you can try.
My Samsung does slideshows from a USB stick by itself. If you can't get office to build a show for you, you could do screen captures saved as .jpg's and save them on the stick.
You can use the alt+prnt scrn buttons to screen cap, then paste in paint, save as .jpg.
Not elegant, but functional...
Thanks, I guess that's the cheapest way to do it :)
Guess my boss will have to C/P and stop bitching :D
