memory bus speed
alanm
vancouver
Hi. I've got pc100 sdram (128mb), but why is my mem.bus speed showing 66mhz? Is mem.bus speed the same as FSB? My Celeron 466 is 66mhz, is that the reason? Low mem.benchmark, so I'm trying to rectify it. Any ideas? Thanks.
P.S. Unknown Mobo (Vtech?) with VIA Apollo pro 133 chipset.
Kato
Addicted Tweaker
Toronto, Canada
WELCOM TO THE FORUMS:clap:
as for you question, you are correct, your memory is running at 66Mhz since your celeron is running at 66Mhz.
i doubt it but check your mobo's manual to see if you can see the mermory bus speed higher.:D
edit: haha, Sonny beat me while i was typing up the post:D
