- Oct 20, 2016
Hello everyone, I hope you're well!
I have been having an odd issue since getting my new build up and running. I'm not entirely sure what to do. My experience troubleshooting is limited, although I've successfully built and overclocked PC's before.
Here's my current equipment setup:
- ASUS Z170 Pro Gaming/AURA LGA 1151 Intel Z170
- EVGA GeForce GTX 1080 FTW GAMING ACX 3.0
- Intel Core i7-6700K 8M Skylake Quad-Core 4.0 GHz LGA 1151
- G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600)
- Acer XB270HU Abprz Black 27" 144Hz WQHD Widescreen LED Backlight LCD G-SYNC Gaming Monitor
- Antec 750W PSU from previous build
I have run prime95 at 4.7 GHz without issue. Temps with a Cooler Master Hyper 212 EVO even at 4.7 GHz stay in the 70's. I tend to keep my CPU at 4.5 and 1.250 V though as to prevent any issues, although I haven't had any issues at a higher OC. Temps rarely above 60 C.
The issue I am having seems to be with my RAM and I have no idea why. By default, unless I enable XMP or change the BIOS settings manually, my RAM is running at 2133 MHz instead of the rated 3200 (timings are also different from specifications).
Overwatch, my latest favorite shooter, works wonderfully when my CPU overclocking is set to auto (i.e. I do not mess with the ratios and let the system do it on its own). It seems to sit at 4.4 GHz. It also runs fine when overclocking just the CPU to higher than 4.4 GHz. My framerates are great (well over 100 most of the time, but I haven't recorded them lately) on all epic (completely maxed out) settings and I get no stuttering or any problems at all.
Once I enable XMP in the BIOS though and attempt to run my DDR at the rated specifications, Overwatch simply fails. My framerates drop into the low 30's and 20's and I feel like I can barely move. I also then get strange behavior in general (like my USB keyboard starts to disconnect and reconnect randomly as if I was plugging it in and out). Both the framerate loss and the keyboard issue also happens in other games when tuning the RAM. It's very strange. I've tried setting the CPU to base at 4.0 GHz and leaving it alone then enabling XMP for the memory only, but still the same issue. I've also tried disabling XMP and just tuning the frequency, timing, and voltage manually and it still messes with the games. If I set everything in the BIOS to optimized defaults (with no overclocking or XMP at all), Overwatch runs great. The only thing I can think of is that the memory is bad, but I ran memtest86 one morning when I had some time. I only made it through one pass before I had to leave but there were no errors in that one pass. I've also run a blend test on prime95 with XMP enabled and I have no issues after 3 hours of testing.
Why would running the RAM at listed specifications cause these framerate issues? Like I said, all I can think of is a RAM problem.
Thank you all so much!
