I'm running ocz pc6400 ddr2-800 dual channel 2gb mem and I keep failing the orthos test at 3ghz on my e6600. I have the settings at 5-5-5-15-4(which comes out at 20 for trc) and its frustrating me getting this error msg:
Type: Blend - stress CPU and RAM Min: 8 Max: 4096 InPlace: No Mem: 1791 Time: 15
CPU: 3009MHz FSB: 334MHz [334MHz x 9.0 est.]
11/23/2006 12:47 AM
Launching 2 threads...
Using CPU #0
Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
FATAL ERROR: Rounding was 0.49609375, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 1 minutes 24 seconds - 1 errors, 0 warnings.
Execution halted.
it also said on other settings like 4-4-4-12 that the rounding was .5------, I have tried 2.00v, 2.05v and I believe 2.10v, im going to try 2.15v @ 5-5-5-15-4 then call it quits. I hope someone can help me with this. I'm running a ocz game x stream box and a coolermaster mars cooling unit on the cpu. My board is an asus p5w dh deluxe. Also the ddr is at 668mhz because i was told to have the 1:1 fsb. if i have to change stuff how can i still attain that also? Thanks.
11/23/2006 12:47 AM
Using CPU #0
Execution halted.
