Hello to all
First time poster off and on lurker. Here's my issue.
Current system
MB ASUS Prime B450M A
Ryzen 5 2600
Corsair Vengeance 16GB DDR4 3200 CMK16GX4M283200C16 8gb each in slots 2 and 4
Sapphire 11296-01-20G Radeon Pulse RX 5600 XT 14GBPS 6GB GDDR6
Antec 750 High Current Gamer PSU
Runs fine and stable with Prime 95 and other benchmarks. Recently tried adding two more sticks of the same exact brand and spec memory for 32 gb and started getting blue screens after adding the other new sticks. The machine runs fine with either pair of sticks installed for 16 gb. It's only when I add the other two sticks that the errors show up. I haven't tried any memory tests because the machine runs fine with either pair of sticks installed so I'm guessing that all the sticks are good.
CPU Z shows the DRAM running dual channel as it should. In DOCP 16 18 18 18 36 the freq at 1596.2. Voltage at 1.35v the voltage shows in yellow in my BIOS on the board.
I was thinking I might have to adjust the timings or voltage a bit with 4 sticks installed. Any ideas what's going on?
TIA for any help or suggestions.
Current system
Ryzen 5 2600
