Memory on 8800GTS 512
Romebaby
CO
Is there a utility that tells what kind of ram (mfg) is on the card? I just got a BFG 8800GTS 512 and don't really want to take the HS off. Thanks!
well mine does over 1100 on stock cooler/volts 24/7 so i am willing to bet its samsung.
no there's no program or utility that tells you that/
Rattle, is that the same BFG card from Newegg that you made me buy as well? :)
If so how far have it overclocked it thus far?
yes same newegg deal for 225 shipped after $30MIR
these are 24/7 clocks on stock cooler with rivatuner dynamic fan speed, 50% low at 45c and gradually increases to 100% at 57c
card rarely goes over 56c though gaming.
I got the same card, same place, same deal.
Core seemes to max at 774, but the mem won't stop. I had it around 1150 with no errors, got scared and stopped. Pretty safe to say it's Samsung I think, just wanted to make sure.
Was this card supposed to come with the SLI bridge?
i can play with my mem all the way to 1175 but its not game stable without a lock up at over 1135 as far as I know. so I figure 1100 is a good place to sit.
I ran a bench on '06 @ 750 1100 and only went from 11472 to 11719 (e6700 stock). That's a descent OC with not much improvement. I'll have to see if gameplay improves much, otherwise stock OC clocks for me.
depends on what you got behind it for a cpu and speed.
I should be around 14k but i havnt benched this card yet, I scored 13,500 with a 8800GT though.
OC your CPU, and you'll see a more pronounced difference. Your getting bottle-necked.
Edit: Also try running '06 at a higher rez if you have the Pro version. If not try an actual game benchmark at a decent rez like Crysis, or FEAR. You'll see a difference!
I can't OC cpu, unless someone knows an unlocked bios for an XPS410. I picked this up about 8 months ago, back when the 6700 was $500 and ram wasn't so cheap, for about $900 loaded.
I've been buying Dell crap the last few years (cheap prices, deduct for business expenses). I need to build a rig, there's too many cpu cycles going to waste.
