- Sep 4, 2003
- Ireland
How r yas?
Would bad ram cause sysyem reboots?
At first i thought i had a hdd problem because i was gettin this message after every reboot :
Checking file system on C:
The type of the file system is FAT32.
One of your disks needs to be checked for consistency. You
may cancel the disk check, but it is strongly recommended
that you continue.
Windows will now check the disk.
Volume Serial Number is 840A-5E5A
Unrecoverable error in folder \Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Internet Explorer.
Convert folder to file (Y/N)? Yes
Convert lost chains to files (Y/N)? Yes
16 KB in 1 recovered files.
Windows has made corrections to the file system.
19533472 KB total disk space.
1585776 KB in 305 hidden files.
7936 KB in 492 folders.
890688 KB in 6071 files.
17049056 KB are available.
16384 bytes in each allocation unit.
1220842 total allocation units on disk.
1065566 allocation units available on disk.
The hdd is a western digital, so i download a prog of their website to check for errors but it passed the 2 tests i ran on it.
So im startin to think its the new ram i put in 2x512mb twinmos pc3200 in a DFI LANPARTY NF2.
A new psu didnt cure the probs either, i put a new 550w one in.
If u can help me out i will be over the moon
that you continue.
