Memory voltage for EVGA X58 SLI LE
NS13Stinger
Gray, GA
I did not see any topics on this and could not find the correct memory voltage (1.65v, 1.8v, etc.) for the EVGA X58 SLI LE. Anyone here know what it is?
redduc900
Inactive Moderator
Portland, OR
Between those two sets, you'd be better off w/ the Corsairs because of the lower spec'd 1.65V voltage. In order to run the A-Datas at the specified 1.75 - 1.85V, the QPI/VTT voltage would need to be increased from the default of 1.15V to 1.25 - 1.35V to keep a 0.5 voltage differential. Plus the fact that the A-Data is only rated at DDR3-1333MHz compared to the Corsair at DDR3-1600MHz. This isn't always an issue, since the OCZ Animal series (rated at DDR3-1333MHz) can reach over 2000MHz at timings of 10-10-10.
