Memory Voltage?
killer7
North Carolina
The options for DDR Reference Votage (I'm asuming RAM voltage?) in my BIOS are 2.6, 2.7, and 2.8. I have 512MB (2x256) of Mushkin 222 series PC3200. Are all of these voltages safe to run at?
search around, you can probably find the maximum safe voltage for your stick. i did for my stick of corsair at the corsair forums, found out mine should be alright til 2.8v
You can safely take Corsair past 2.8v. Corsair just will not honor the warranty if they can prove you were operating past that voltage. That is why you saw 2.8 at the CORSAIR forums.
Hammer
mushkin allows up to 2.7v under warranty i believe, that's what their admins recommend to be the max without risk of damage to the ram on their forum
Screw warrenty, lol. Also, I get all my stuff from a store that I work at as a technition (got lucky, im only 15). They overclock alot themselves and just tell you to take everything back to stock when you bring it in if it's not working. Then they can't "prove" you have been overclocking even though they know you do. lol
