- Jan 23, 2003
can anyone tell me anything more than this about this protocol..
"TCP/IP version 6. The next-generation version of the internet protocal that provides communication across diverse interconnectd networks."
That's what XP say's about this...
I'm wondering why it only seem's to work when the regular tcp/ip protocal is install, and if it's so much better how come it isn't install by default. I have been haveing problems with a microsoft wireless router so i decide to check my settings and such. The connection from computer to computer on my internal lan was limited to 25% of the 100mbps that i had before i did the latest firmware upgrade. I would down grade, but the other firmware is just way to buggy for me...so i decided to stick with the lower speed, stability, and hassle the micrsoft tech support....which i did and they say there working on new firmware (yeah right). Well, anyway...i decided to install the Version 6 tcp/ip and i got 50mbps in my internal lan....i was like wow..
I thought it would be a good idea to learn more about this protocol...so if you know anything or know where i can get the info plz post...thanx.
If you happen to know anything about getting my full 100mpbs on the mn-500 wired and wireless router back....you can add that to...but i mainly want to know about the main topic...thanx.
