- Oct 12, 2001
- Los Angeles
Well I received my 2 blocks from Cathar today, Thanks Cathar!! This block performs, no doubt. I won't post hard numbers yet as the block has only been mounted for 2 hours and the system is not fully bled, nor is the AS3 settled. I will say that it is significantly better performing than ANY block I have ever used (Maze 2 & 3, D-tek Spiral, TC-4, Swiftech MCW462-U and UH). Again, I run an XP 1600 at 10 x 190, 2.0V and I run FAH 24/7 so this is my "load". Here is a screenie. These are ON DIE readings.
Excellent job Cathar!! Indeed you have raised the bar.
