Microphone Attachment on Headset
Erray
Hi,
I own the ATH M50X Studio Headphones however as many of you may know, they're exceptional headphones with only a single drawback, that being the lack of a microphone.
I don't want to replace these headphones for an alternative headset that does include a microphone, nor do I want a microphone that isn't attachable to the headset itself... purely for inconvenience. Although, I appreciate microphone quality may be improved, quality isn't my main concern... to an obvious extent.
Basically, I'm here to ask you wizards for something that I can buy to attach onto my headphones, something like this: http://www.modmic.com/
I don't want to bother with modmic because the price seems fairly steep and it's based in the US, I need a UK shopping link.
Please drop a few links below to some decent and cheap'ish mics. I don't want absolutely sh** quality, nor do I want it to be disgustingly clear.... Just as average as you can get.
Thanks!
Janus67
Benching Team Leader
I don't know if the M50X has removable plug into the headphones, but if it does you can see if the v-moda boom mic attachment could work for you.
https://www.amazon.co.uk/V-MODA-Boo...&qid=1461681420&sr=8-1&keywords=vmoda+boompro
FWIW modmics are available in the UK:
https://www.amazon.co.uk/ModMic-OMN...ie=UTF8&qid=1461681386&sr=8-1&keywords=modmic
Other than that you can look into basic clip-on mics, I've heard there's a sony clip-on that is supposed to sound pretty decent.
https://www.amazon.co.uk/Sony-ECMCS...d=1461681447&sr=8-1&keywords=sony+clip+on+mic
E
Erray
https://www.amazon.co.uk/Audio-Tech...qid=1461681421&sr=8-1&keywords=audio+technica
These are the headphones I have, the cord is removable if that's what you mean?
Thanks, I'll check both out now.
Janus67
I updated my post above, modmics are available looking at amazon.co.uk
E
Erray
So the v-moda boom mic attachment arrived today and unfortunately it didn't fit in the Audio Technica Heaphones... the cable was too small.
DAMN!
