- Mar 25, 2002
- Washington State
I've beend doing a lot of forum searching and reading, and haven't been able to find a thread about this. I know that a powerful pump is needed to overcome head pressure and that no pump will actually move water as fast as it is rated to do in a closed system.
As I think about water flowing through my eventual water cooling system, when the water goes through the radiator it gets to go through a fun little cooling ride to strip out the heat and I'm thinking that if it goes through the radiator TOO fast that it might not have all the heat possible removed from it.
I think a 230 GPH pump (I'm eying a maxi jet 900) would really be a strong enough pump, even given that it won't actually move the water that fast.
So let's hear some debate...mid range pumps VS the HUGE volume pumps. Which do YOU prefer, and why?
K1
K1
