Hey.
I'm building a 8700K setup, and based on the reviews I read, it seems like the H115i would fit my needs best.
Currently I have a H110 in a Fractal Arc Midi R2, in push-pull intake. I had to mod the case and it was dirty work, would prefer to avoid that stuff.
I'm a bit wary of mounting the rads on top
1. If I make it exhaust, it'll have lowered cooling peformance.
2. If I make it intake, it just doesn't feel so right. That'd mean I'd have to exhaust both in the front and rear, right? It just feels like it'd be less efficient than intaking from front and exhausting @ top & rear.
Is there a mid-tower that can support a H115i for frontal intake?
If there isn't, anyone has a good full-tower recommendation? (i'd have a hard time fitting in a cube-case in my setup)
If I get another arc midi r2 for the H115i, it'll fit in the with same modification as the H110 did?
There was some guide for the H110 Arc Midi combo, but couldn't find one about the H115i.
Do they mount the exact same way? Cause I think it's just a matter of luck that the H110 fits in this case with some modding.
